New Holland LX885 panel lights
stevejeri
When I sit in the seat, the hour display and fuel guage light up, it beeps, starts, runs, but none of the other lights light up on the display. Today, I was moving some dirt, and when I would put it in a strain moving forward or backward for a little bit, it would start beeping. Without any of the lights lighting up, I didn't know why it was beeping at me. After a little bit, it would stop beeping. All fluids show full. The bucket was a little jumpy when I would raise it or tilt it back up after a dump. Any ideas? Oh, I did check the power to the plug on the control board and all checked out good. (power, seat switch, seatbelt switch, etc.)
If your seat switch is getting intermittent connection it may be giving your solenoids lock out solenoids an open/shut with each arc of a loose wire on the switch or a bad switch. The.seat switch will lock out lift and tilt solenoids. The seat belt switch will only lock out tilt solenoid. So if its jittering raising the boom and tilting the bucket look at the seat switch. Also look for the fuse for the solenoids. The fuse holders on mine got bad. Fuses wiggled and arced in the holder.
Check your cab ground also. It still doesnt explain the lights but may explain the hydraulics not moving smoothly.
