New Holland LX885 oil leak from side
LadyLapstrake58!
Hi All, Thanks for having me here and thanks in advance for any insight you may offer to my problem. I had noticed a hydraulic oil leak (on the outside) from right side of the LX885Turbo between the lower fender edge and center drive access plate when the machine was running. I don't see any obvious leaks when looking at the hoses, lines, etc. Prior to running the machine I had checked & topped off the oil at the final drive gear box dipsticks. There is an indicator on each dipstick that is about an inch from the bottom, and I assumed that is a low fill indicator. My question is, if these reservoirs are slightly overfilled, will a leak show up at this outside location? Machine was running fine, but I stopped it because I didn't want to have an issue.
