New Holland LX 665 Wont start all electric/fuel is ok
crush3d
Hello, I just purchased a LX665 that had quit running and I am working on sorting it out. I was hoping for soft fix however it seems to leaning toward a hard fix. I have checked and tested all the electric and everything seams to be good including fuel delivery. The motor turns over and will puff black smoke however will not fire. I have changed the glow plugs and even did a bypass to heat them and still motor will not fire. I have given it a quick snort of starting fluid and it will hit harder (does not lock)but again the engine will not start. I did attempt a compression test when glow plugs were out and each cylinder does have pressure but I was not able to get reading with the equipment I have so I placed a finger over each hole and seemed like plenty of pressure and fuel mixture was being blasted back. Is it possible for the timing to be off just a smidge without wrecking the top end. Before I tear the entire motor down does anyone have advice on possible easy fix that I may be overlooking. Oh on last bit of info, it was running fine and just shut down however the previous owner stated the oil was low and I found the hydraulic fluid low. He also stated there were no loud knocks or rattles when it stopped and described the shut down as he was driving and it sputtered and died like the fuel shut off. Please advise. Any information would be greatly appreciated. Just an old farm boy trying to make things work :-)
One other thing is it possible the starter not turning over fast enough may be culprit, it does drag a bit.
Check for oil in your coolant. My starter had to be rebuilt a couple because it wasn't rolling the engine over fast enough.
Do not use either if you need something use wd40 I would see if it jumped time and then compresson check
Is it possible for it to jump timing without hitting the valves, plus being timed with gear drive I would expect catastrophic failure. I just was cranking on it and it seems if it would just spin it over little faster it would take off. It seems to want to fire. You cant pull start these can you LOL. If I crank it long enough it is belching black smoke (not white or blue). Oil is good no water...
