new holland l555 diesel engine quitting
kr726
The engine will run for a minute and the dies out but I can keep restarting it each time.
yes it is so i will try it and will let you know.Thank you for your response
Get some 911 fuel treatment and add to it after changing the filter. If it sill does it hand a light bulb or add heat to the filter and injection pump. I always run fuel treatment in mine and use 911 if I have problems in the winter. I have had a lot of problem with the fuel this year jelling
Twice for me, first time filters and 911 fixed it , second time 911 did. But when I put the fuel from the filters in a pan overnight in the cold it was fine in the morning. I am going back to mixing my own 50/50 #1 and #2 instead of depending on the station blend. But I don't use all that much so it isn't a big deal to do that.
