Other Brand Skidsteer Forums
New Holland Skidsteer Forum
New Holland L425 will drive and steer but no up/down or tilt fuctions
Reply to thread
Message
<blockquote data-quote="russ2far" data-source="post: 97564" data-attributes="member: 13870"><p>Thanks for the crossed fingers they worked. I had up/down boom and tilt function for several minutes then they stopped. I pulled the screen and it was clogged again with a thick gray syrupy consistence stuff. I sprayed it of with some engine degreaser put it back in and the functions work again for 5-7 minutes then stopped again. So I cleaned it again and got them working again. I back drug my drive way, pushed around a few bigger rocks, didn't use it hard but did get 15-20 minutes of use out of it then shut her down. I changed both filters after that. I think I will run and clean the screen after 15-20 minutes couple more times then see if I can't drain the hydraulic fluid and put in new, change the filters again and hopefully she will be good to move my snow this winter. Anyone have any cool starting tip for these old Wisconsin engines? Anyway, thanks for all the help, I think I am going to really enjoy this little machine. Russell</p></blockquote><p></p>
[QUOTE="russ2far, post: 97564, member: 13870"] Thanks for the crossed fingers they worked. I had up/down boom and tilt function for several minutes then they stopped. I pulled the screen and it was clogged again with a thick gray syrupy consistence stuff. I sprayed it of with some engine degreaser put it back in and the functions work again for 5-7 minutes then stopped again. So I cleaned it again and got them working again. I back drug my drive way, pushed around a few bigger rocks, didn't use it hard but did get 15-20 minutes of use out of it then shut her down. I changed both filters after that. I think I will run and clean the screen after 15-20 minutes couple more times then see if I can't drain the hydraulic fluid and put in new, change the filters again and hopefully she will be good to move my snow this winter. Anyone have any cool starting tip for these old Wisconsin engines? Anyway, thanks for all the help, I think I am going to really enjoy this little machine. Russell [/QUOTE]
Verification
Post reply
