Our l225 did the same thing and it was a 15amp fuse in the first fuse box.Middle of second row.I have a l228 new holland skidsteer stuck wont start engine codes 1051 and 9153. cant find bad fuses? was running good then when I shut off wouldnt start.
I’m having the same issue on my c232. Was running the machine & it just cut off. Had to use the emergency release to exit machine. I’ve checked all fuses- and the battery is perfect. Can anyone help?Our l225 did the same thing and it was a 15amp fuse in the first fuse box.Middle of second row.
Same error codes: 1051 & 9153I’m having the same issue on my c232. Was running the machine & it just cut off. Had to use the emergency release to exit machine. I’ve checked all fuses- and the battery is perfect. Can anyone help?
Did you ever find out what was wrong?Same error codes: 1051 & 9153
Did you ever find out what the problem was? Having the same issue after replacing the engine wiring harness.Same error codes: 1051 & 9153
