New holland 781 - wrong hydraulic fluid
Mudgyver
So, I wasn't paying attention and grabbed the wrong jug. Machine calls for J20a and it got, maybe 2 gallons of aw46 toping off the system. I know, way off. Anywho that's about 10% of fluid capacity. Pay the stupid tax and drain all the fluid, or should it be alright?
well, I think you might be wrong on both fluids, as from my memory, the older NH, used either 30 w or 10w30 oil in there hydraulic systems, same oil as in there motors at the time, so neither of the fluids you have been using are right!(most likely)
that said, I know from having seen many posts of where folks switched to different fluids and claimed they were fine, even mixing fluids
I GUESS you MIGHT be fine as is! its a guess!
as there is never a way to fully drain a system completely, there is always old fluid in hoses and motors/pumps and so on!
which add up to a lot of fluid, left behind, that gets mixed, this is why they basically tell you to use correct fluids, so there is no chance of having side effects of mixing different blends/weights designs of fluids,
mixing doesn't mean it will be BAD but also doesn't mean it cannot be bad, either!
So like I said, NOT using the OEM correct fluid is, up to you, and no one here can tell you it will be 1000% Good for your system
they designed things to be used with fluids they found worked best
altering off this, is a gamble of sorts
some times you will be fine, but I gather others times you could run into issues
your machine, your call!
