I need a steering damper for a NL L445. NL has discontinued the part and it now states this (, Steering Damper, Converts Volkswagon to Monroe) on the website. Has anyone every replaced it this and has the aftermarket part number? Thanks in advance.
I tried that didnt have any luck with that. Ive called a bunch of places also. Here are the part numbers. 259820 and 619499.Probably the best option is to just google the part number; chances are there will be a NOS one on ebay, or at least the number will be referenced in the superseded item number.
If you get too many unrelated hits for same numbered stuff, add New Holland before the number in the search field.
The pics of the NLA used ones look like they come apart, so another gas spring can be modded to fit. The 259 number goes to a Toyota application, which should be readily available.I tried that didnt have any luck with that. Ive called a bunch of places also. Here are the part numbers. 259820 and 619499.
