Bobcat Skidsteer Forums
Need help with a Bobcat 642 (ford 1.6) Mod # 2274E motor
Reply to thread
Message
<blockquote data-quote="4510" data-source="post: 89243" data-attributes="member: 12865"><p>^+1 If you haven't switched to electronic ignition, I highly suggest it. Before converting to electronic I bought all new ignition parts, and got the machine running pretty good for a month, but it sat 3 weeks and then started acting up again. It would backfire, causing fuel to shoot out of the carb into the air filter, at the same time the governor was jumping all around. I thought I had carb or governor problems. I bought the electronic ignition and solved all issues with the turn of the key. $282 from northern power products. Plug and play. The machine has never run better. Now I am on to the hydraulic leaks.</p></blockquote><p></p>
[QUOTE="4510, post: 89243, member: 12865"] ^+1 If you haven't switched to electronic ignition, I highly suggest it. Before converting to electronic I bought all new ignition parts, and got the machine running pretty good for a month, but it sat 3 weeks and then started acting up again. It would backfire, causing fuel to shoot out of the carb into the air filter, at the same time the governor was jumping all around. I thought I had carb or governor problems. I bought the electronic ignition and solved all issues with the turn of the key. $282 from northern power products. Plug and play. The machine has never run better. Now I am on to the hydraulic leaks. [/QUOTE]
Verification
Post reply
