Bobcat Skidsteer Forums
need help please
Reply to thread
Message
<blockquote data-quote="Tazza" data-source="post: 32818" data-attributes="member: 82"><p>It does sound like the spool seals.</p><p>Not the easiest things to access to work on though, ensure you don't put any force on them from side to side while removing them. If you bend it, it will bind in the housing.</p><p>A seal kit is about $50 from memory, the hard bit is installing them.</p></blockquote><p></p>
[QUOTE="Tazza, post: 32818, member: 82"] It does sound like the spool seals. Not the easiest things to access to work on though, ensure you don't put any force on them from side to side while removing them. If you bend it, it will bind in the housing. A seal kit is about $50 from memory, the hard bit is installing them. [/QUOTE]
Verification
Post reply
need help please
