Mattholew
- Joined
- Jan 3, 2020
- Messages
- 4
So recently I've begun to smell a very slight hint of burning oil coming from my Bobcat occasionally. Mostly when I go backwards which I believe is just because I'm backing into the smell. It has never done this before and just started after I replaced two hydraulic lines and both filters. Changed engine oil and filter. And replaced all the oil in the chain case. The chain case was almost out of oil when I changed it. Also when I replace the engine oil I accidentally overfilled it a pretty decent amount. I figured that might be it so I took the oil level down to the correct height. But I am still getting a whiff of the burning oil smell occasionally. Any idea what may be causing this or things that I should check?
