Bobcat Skidsteer Forums
my 743 will not turn moves forward and backwards fine
Reply to thread
Message
<blockquote data-quote="mllud" data-source="post: 18057" data-attributes="member: 1012"><p>This is a paragraph from one of Tazzas previous posts about the hidden filter</p><p>Ok, as you have the older style you have a hidden suction line filter. Left hand side, middle hose. Remove it and the fitting that screws in the port block. Behind there is a spring and bronze filter, you may need to remove it with pointy nose pliers. Watch the fitting doesn't fly out at you as there is a spring there. Replace or at least give the filter a good clean in kero or diesel and blow it down with air. That should fix your drive problem.</p></blockquote><p></p>
[QUOTE="mllud, post: 18057, member: 1012"] This is a paragraph from one of Tazzas previous posts about the hidden filter Ok, as you have the older style you have a hidden suction line filter. Left hand side, middle hose. Remove it and the fitting that screws in the port block. Behind there is a spring and bronze filter, you may need to remove it with pointy nose pliers. Watch the fitting doesn't fly out at you as there is a spring there. Replace or at least give the filter a good clean in kero or diesel and blow it down with air. That should fix your drive problem. [/QUOTE]
Verification
Post reply
