mustang 930A weak drive on right side
BellH
My tractor has weak drive on the right side it gets worse at some times and nearly disappears at others It seems like it's only weak if I go forward but seems normal in reverse. Could this be a valve problem? On occasion the left steering lever can get stiff in one spot . If I pull harder it gives , this is intermittent as well.
A good test is to swap motors from side to side, see if the issue moves to the other side.
There is a possibility that the issue is a shuttle valve in the motor that is sticking.
