Mustang 345
sadams74
Hey guys I got a 345 mustang i had in the shop cist me 2300nandvstill running like crap. I gave them a governer to put on but it was the wrong one so when they put it on it runs like crap. So I've unhooked the governer and have tried just giving the carb throttle. I start it and it revs high then goes down to idle but the min I try to rev it then it dies. Before I took it I added fluid and it was doing same thing. Could it be dying because its building to much pressure from faulty valve??
what engine is in that loader, they had a deutz diesel , and i believe it also used a ford V4 gas, or a wisconsin engine
The governor on a 1700 is supposed to be easy to tune (according to a recently deceased friend), but it's been a b***ch to me. A linkage broke on it years before I rebuilt it and it still ran fairly okay after I rigged it. I just learned to "play it by feel". After the rebuild with all the expected improvements and loss of oil leaks, it hasn't been a happy driver. The alternator belt rigging is probably the problem as it originally had a generator and tensioning is subject to fluctuation. I do have the pamphlet for instructing but having to fiddle with the linkages that can't be easily reached is a stumbling block. That and I don't really need to use it much is a factor. I like FordV4parts.com for parts and have had positive results dealing with them, above and beyond the normal interactions. They might can help advise. I'll get my instruction pamphlet next week when at the garage and help as much as that will. One thing I did learn was ethanol regular fuel is barely usable in my machine. I'm not sure what compression the 1700 has but after I learned to run premium it was always more dependable.
