mustang 345 question
mayne
Hello, I 'm new here and hope someone can help. I just bought an old 345 mustang. There is water in the chain case and I would like drain them and put in new fluid.But where are the drain plugs? Please help.
there should be a drain plug on the bottom of each oil tank.if your standing at the rear of the machine you will have your hydraulic tank in the center.on each side of that there is the gear oil tanks for the drive assembly.the drain plugs are located on the bottom of each.if your starting from scratch with fluid for the drives the dealer told me to run universal trans fluid.hope this helps.
