Mustang 2109 fuel tank removal
GRN250
Has anyone removed the fuel tank from a Mustang 2109 or Gehl 7810? I purchased a 2109 needing a few repairs but haven't been successful in finding a detailed service manual on-line. Any help is appreciated.
The manual didn't explain how to perform this task so I will share what it took for me to remove the fuel tank. 1 Disconnect the fuel sending unit wiring (one brown and one white wire). 2 Disconnect the fuel supply (rear of fuel tank) and return (right side of engine block) fuel lines. 3 Remove the rear door from the skid steer making sure to disconnect the electrical plug at the left side of the cover near the hinge area. Removing this cover requires removing two bolts and lifting up on the cover about 1 1/2 inches. 4. Drain and remove the radiator/hyd. cooler. This also requires removing two bolts and lifting up to get the radiator to disengage from the mount. 5. Loosen and remove the bolt going through the right side engine mount/isolator. This this the mount with the rubber pads. 6. Using an engine support. lift the engine from the top until the engine lifts off the right side engine mount about a 1//2". 7. Remove the five nuts securing the right side engine mount to the skid steer chassis and remove the mount. This is a very tight area so be patient as it will move. 8. You should now be able to remove the fuel cell. Be careful not to damage the fuel sending unit wiring stud when removing the tank. 9. Reverse this procedure to install the tank. Hope this helps.
Thanks for sharing your knowledge, i'm sure others will find this helpful.
Very nice to see that you don't need to remove the engine/pump to get the tank out, only lifting it so minimal parts need to be removed.
later model Bobcats need to have the engine/pump removed to get it out, i don't think there is enough space to lift/tilt the engine back so a bunch of hoses and stuff needs to be removed.
