Mustang 2050
Jbohannon
I am still having issues with the right side drive motor. A couple of years ago my motor on that side went bad and I replaced it. From the very beginning it was not as stong as the left side and not long after it would not drive at all. So then I purchased a used one since this is an old machine and although it is better it is still less power than left side and getting weaker. Is there something else that could be wrong besides motor ?
seems to me you may have a problem with the pump too, depends what failed on the first motor
it could have put metal pieces into the pump & damaged it if u still have the first motor dissasemble it
also take filters off dump into a clean pan inspect for metal fillings, if pieces get up to the the pump u will loose power over time. if a motor fails the pump to that same side should also be disasembled
