mustang 2044brakes wont release
robbie5919
hi i have a mustang 2944 the left button for the brakes does not light up and can not hear the solenoid click checked the solenoid and it is good i hoocked a pair of jumper cables the the battery and then to the 2 wirers from the solenoid and got it to relese the brakes i then hocked up to wirers from the battery and to the solenoid and the brakes wont release. i then took a wirer from the switch and ran it to a toggle switch an then to a 4 prong relay and then to the coil but nothing happens brakes are still locked help please
U will find a timer connected to the brake switch, the location of the timer is directly behind the switch mounted to the rops frame. it will have a 4 wire plug with 2 orange 1 black and 1 red. follow the 2 orange wires back from the plug u will find a male & female spade connection. un plug both orange wires and connect the 2 orange ones in the rops harness side together, bypassing the timer. u do not have to do anything with the black and red wires. your brakes should release and work normally.
if that doesnt work u may have a faulty brake switch or control module
