Other Brand Skidsteer Forums
Mustang Skidsteer Forum
mtl20 front hyd not working
Reply to thread
Message
<blockquote data-quote="Tazza" data-source="post: 95791" data-attributes="member: 82"><p>I guess you can use a multi-meter to check if the switches are working, there should be a connector under the seat, at the base of the steering lever. If you know the switches are working, you will need to move on and see what else it could be.</p><p>I guess it could be the coils or stems that control the aux hydraulics too. If they haven't been used for a while, they can stick.</p></blockquote><p></p>
[QUOTE="Tazza, post: 95791, member: 82"] I guess you can use a multi-meter to check if the switches are working, there should be a connector under the seat, at the base of the steering lever. If you know the switches are working, you will need to move on and see what else it could be. I guess it could be the coils or stems that control the aux hydraulics too. If they haven't been used for a while, they can stick. [/QUOTE]
Verification
Post reply
