Bobcat Skidsteer Forums
mini 463 cab heater
Reply to thread
Message
<blockquote data-quote="jerry" data-source="post: 72007" data-attributes="member: 931"><p>Wait till Monday, high here of -10 f so we better cover the banana trees.</p><p>I put a heater core and fan on the new Holland and the fittings seemed small but it does heat pretty good. Have you checked your engine temp above and below the thermostat? Infrared thermometer will tell you if the thermostat is not working right. My cab is not sealed all that well and I would like to have the factory heater add-on but too cheap to spend 600.</p><p>The 12v heaters may keep one ear warm if you put it really close otherwise no..</p><p>Reason I mention the thermostat is mine was stuck open and engine never went over 160.</p></blockquote><p></p>
[QUOTE="jerry, post: 72007, member: 931"] Wait till Monday, high here of -10 f so we better cover the banana trees. I put a heater core and fan on the new Holland and the fittings seemed small but it does heat pretty good. Have you checked your engine temp above and below the thermostat? Infrared thermometer will tell you if the thermostat is not working right. My cab is not sealed all that well and I would like to have the factory heater add-on but too cheap to spend 600. The 12v heaters may keep one ear warm if you put it really close otherwise no.. Reason I mention the thermostat is mine was stuck open and engine never went over 160. [/QUOTE]
Verification
Post reply
mini 463 cab heater
