Other Brand Skidsteer Forums
Mustang Skidsteer Forum
mid 70's Mustang 310
Reply to thread
Message
<blockquote data-quote="littleskidsteer" data-source="post: 54952" data-attributes="member: 7384"><p>Good idea. I found out that Crown Vic wheels have the same hole pattern as the 310 but are 17" rims. Once I put rubber on them, they may not fit within the axle to axle dimension. Also, the offset of the Crown Vic is way to the outside of the rim, should probably be closer to center for my application. Thanks, I'll check your resources.</p></blockquote><p></p>
[QUOTE="littleskidsteer, post: 54952, member: 7384"] Good idea. I found out that Crown Vic wheels have the same hole pattern as the 310 but are 17" rims. Once I put rubber on them, they may not fit within the axle to axle dimension. Also, the offset of the Crown Vic is way to the outside of the rim, should probably be closer to center for my application. Thanks, I'll check your resources. [/QUOTE]
Verification
Post reply
