Manuals and oil change for 751c with pug eng
Hacksawjoe
Im trying to find manuals for my 751c with pug motor.Free or cheap.Also how many qts oil and what brand oil do you recommend.Bought this off my fatherin law and hes not around now.Thanks
The manual says 6 qts with filter change. Use a high quailty diesel rated oil with a weight based on the outside temps. 15w40 is good for 5-100F or 5w30 if you are in a area that get below 0F
Here's where I uploaded the manuals. http://www.mediafire.com/?n45meqt9agkbr
Thanks for the info on 751c.Put info into a file. Any other info as to good or bad on this machine would be helpful.
Its an excellent machine, essentially the same as a 753, just a pug engine instead of the Kubota that the newer ones run. The pug runs smooth as, but parts are costly. I found it had heaps of power, did all i ever needed to do.
