Bobcat Skidsteer Forums
m610 keeps wanting to stall under load
Reply to thread
Message
<blockquote data-quote="mmsllc" data-source="post: 96048" data-attributes="member: 13117"><p>I would check the entire ignition system out, but I would have the carb rebuilt or replaced. When they sit, they go bad quickly. Most of the ignition system parts do not go bad by sitting around, but usually by wearing out from use. Today's gasoline is just straight garbage. With that being said, I would focus on the carb. Checking the compression on the engine & the ignition system will not harm anything, though.</p></blockquote><p></p>
[QUOTE="mmsllc, post: 96048, member: 13117"] I would check the entire ignition system out, but I would have the carb rebuilt or replaced. When they sit, they go bad quickly. Most of the ignition system parts do not go bad by sitting around, but usually by wearing out from use. Today's gasoline is just straight garbage. With that being said, I would focus on the carb. Checking the compression on the engine & the ignition system will not harm anything, though. [/QUOTE]
Verification
Post reply
