Holding the valve open? you mean for the lift? if so, thats normal. When you activate a function, the oil is diverted to that section, so the pressure will not be available at the aux connection.I put a gauge on the aux. and the reading was between 1750 and 1800 psi. however, while holdind the valve open that psi quickly diminished. Is the problem in the valve? Im not a hydraulics guy but I think that if it were the pump the psi reading would not have been where it was.
