Bobcat Skidsteer Forums
m371 crankshaft/clutch
Reply to thread
Message
<blockquote data-quote="Ashkicker" data-source="post: 37628" data-attributes="member: 2357"><p>Hi Murphr, I have a 371 that had the original engine and developed a ticking noise so I decide to replace the engine with another K 321 and once I received it from fed ex I found the crankshaft diameter with smaller so none of the 3 pulleys worked on it. Kohler made a motor just for the 371 that had a fatter crankshaft for the torque needed to run the 3 pulleys. Needless to say I did make mine work but was very tight in making the pulleys line with with the one's on the bobcat. So if your going to swap out you may have to get a little creative. hope this helps</p></blockquote><p></p>
[QUOTE="Ashkicker, post: 37628, member: 2357"] Hi Murphr, I have a 371 that had the original engine and developed a ticking noise so I decide to replace the engine with another K 321 and once I received it from fed ex I found the crankshaft diameter with smaller so none of the 3 pulleys worked on it. Kohler made a motor just for the 371 that had a fatter crankshaft for the torque needed to run the 3 pulleys. Needless to say I did make mine work but was very tight in making the pulleys line with with the one's on the bobcat. So if your going to swap out you may have to get a little creative. hope this helps [/QUOTE]
Verification
Post reply
