Bobcat Skidsteer Forums
m-610 rear scarifier mounting
Reply to thread
Message
<blockquote data-quote="6brnorma" data-source="post: 80935" data-attributes="member: 5914"><p>rjardo……I lost a post somehow….don't know where it went. To answer your question …….the bushing serves as the wear surface. So what I do is use the largest size bolt for hole in the "bracket". I went to a steel supply and got pipe that just fit the bolt and in the largest wall size possible. I think it was nearly 1/2 inch thick. Then cut pieces to about 2 1/2 inches in length….dress up and then slip over bolt and bolt into each "bracket"</p></blockquote><p></p>
[QUOTE="6brnorma, post: 80935, member: 5914"] rjardo……I lost a post somehow….don't know where it went. To answer your question …….the bushing serves as the wear surface. So what I do is use the largest size bolt for hole in the "bracket". I went to a steel supply and got pipe that just fit the bolt and in the largest wall size possible. I think it was nearly 1/2 inch thick. Then cut pieces to about 2 1/2 inches in length….dress up and then slip over bolt and bolt into each "bracket" [/QUOTE]
Verification
Post reply
