LX885 hydraulic temp alarm
stevejeri
When I pull all the way back on the right stick to go backwards, the hydraulic temp alarm beeps, and says the hydraulic oil temp is high. Doesn't beep as long as I don't pull it all the way back. Is flow somehow restricted causing the oil to overheat, or is it just a sensor malfunctioning? As soon as I let the stick go back forward a little, the temp reads normal. Just can't back up full speed. Thanks.
The temp sender is to the side of the right hydro lever. The lever is probably shorting the wire to the sender.
