Hi all, working on a new to me machine. After a lot of pressure washing I’ve located the main source of a fluid leak. The seal under the arm in the first pic is the culprit. Arm seams to be seized to the output/input shaft. Hesitant to beat on it knowing what it’s connected to. Can I safely heat it to break up the adhesion?
According to the parts diagram there is a square key under the arm that interfaces with the shaft - there a trick to this? Currently just using the claw of a hammer to pry it up but it’s not moving. Soaked with PB blaster for 24 hrs. Any advice is greatly appreciated.
