MADDADDY30
- Joined
- May 4, 2022
- Messages
- 25
Hey guy!
I've had another thread for several weeks seeking help with a ghost leak on my 865, I thought I'd share what I found and ask some advice. So I pulled the LH pump today finding that due to a motor mount failure the bottom of the servo rubbed thru the frame causing a leak from wearing down the servo casing. Question is. This hole in the center of the metal is where the fluid is coming from. Can I fix this? Weld it? Build and weld a cap of some sort or am I screwed.? It appears the metal piece comes out as to the set screw in the housing. Any help is much appreciated.
