LX865 cranks but won't start
mowcanic16
Hey guys, I have a lx865 skidsteer and I can't get it to start. I have it in service mode and I keep getting the error2 code. It has a new battery, all the fuses are good and I have replaced the relay. The fuel solenoid pops when I turn the key into run. The wiring for seat safety switches are all good as are wiring from the fuses etc. I am completely stumped. So any help or insight would be greatly appreciated.
Did you actually check if you had power to fuel solenoid on the injection pump? The solenoid does not pop but clicks softly. The pop you hear is probably the cold start relay. If you have power to the fuel solenoid, then be sure the fuel system does not need bleeding.
I have not checked to see if I have power at the fuel solenoid. I'll hopefully have time tomorrow to check. If I do have power to the solenoid, what would be the next step in my troubleshooting?
Then you are left with three possibilities, solenoid bad, injection pump bad, or it is out of fuel and the system need bleeding.
