Other Brand Skidsteer Forums
New Holland Skidsteer Forum
Lx665 max speed & throttle stop bolts
Reply to thread
Message
<blockquote data-quote="Patcon" data-source="post: 98937" data-attributes="member: 13682"><p>I am not referring to the throttle stops on the timing cover bracket where the throttle attaches. I believe, I have those adjusted correctly. I am referring to the bolts under the injection pump that thread through the block into the timing cover area and affect the operation of the governor. The factory manuals provide no direction on setting them "they are factory set and don't require adjustment" but if you rebuild from a bare block they will have been removed. I haven't been able to find any info on setting them correctly.</p></blockquote><p></p>
[QUOTE="Patcon, post: 98937, member: 13682"] I am not referring to the throttle stops on the timing cover bracket where the throttle attaches. I believe, I have those adjusted correctly. I am referring to the bolts under the injection pump that thread through the block into the timing cover area and affect the operation of the governor. The factory manuals provide no direction on setting them "they are factory set and don't require adjustment" but if you rebuild from a bare block they will have been removed. I haven't been able to find any info on setting them correctly. [/QUOTE]
Verification
Post reply
