Other Brand Skidsteer Forums
New Holland Skidsteer Forum
LX 885 Hydraulics locked out
Reply to thread
Message
<blockquote data-quote="shelby" data-source="post: 34235" data-attributes="member: 3818"><p>.....I have encountered this lock out situation too....... I checked my seatbelt switch and seat switch, everything seemed to be fine, with the electronic end(I was fit to be tied).......now for what ever the reason, every so often I spray that seatbelt clip with BrakeKlean, and then blow it out with compressed air, and for some reason, it seems to work again.....it will work 100 times or more, than takes a notion to lock out again......repeat the treatment, and away I go again.....I actually contemplated replacing the seatbelt receptacle, just out of sheer frustration, but this procedure seems to do the trick, and we have 5200 hours on the machine now......hope this helps you out, there is nothing more frustrating.......S</p></blockquote><p></p>
[QUOTE="shelby, post: 34235, member: 3818"] .....I have encountered this lock out situation too....... I checked my seatbelt switch and seat switch, everything seemed to be fine, with the electronic end(I was fit to be tied).......now for what ever the reason, every so often I spray that seatbelt clip with BrakeKlean, and then blow it out with compressed air, and for some reason, it seems to work again.....it will work 100 times or more, than takes a notion to lock out again......repeat the treatment, and away I go again.....I actually contemplated replacing the seatbelt receptacle, just out of sheer frustration, but this procedure seems to do the trick, and we have 5200 hours on the machine now......hope this helps you out, there is nothing more frustrating.......S [/QUOTE]
Verification
Post reply
