I have an LS180 that started acting up. I went to start it and it would crank over, but wouldnt fire. It sounded odd when cranking(sounded different), but cant explain what it was. It didnt even try to fire. I cracked an injector line to see if I was getting fuel. I go in to crank it, and now it wont crank. No solenoid click, nothing. After investigating I find there is a 5 amp fuse in the operators compartment blown, and the main 15 amp key switch fuse in the engine compartment is blown. I swap a fuse in the 15 AMP spot, and the machine cranks over, but blows the fuse again. I checked out the service manual, and there really isnt anything for troubleshooting the key switch fuse. Since this is on the "control" side, the only loads are the relays right? Could I have a bad relay?
