Other Brand Skidsteer Forums
New Holland Skidsteer Forum
LS170 Forks fall off
Reply to thread
Message
<blockquote data-quote="Tazza" data-source="post: 56027" data-attributes="member: 82"><p>You may need to re-weld the metal bits on the bottom. If they were not done right, there may be too much of a gap between the bottom of your quick attach and the fork carrier allowing it to slip out. I have about 1/8" of space between the QA and the bottom plate that the pin locks through.</p></blockquote><p></p>
[QUOTE="Tazza, post: 56027, member: 82"] You may need to re-weld the metal bits on the bottom. If they were not done right, there may be too much of a gap between the bottom of your quick attach and the fork carrier allowing it to slip out. I have about 1/8” of space between the QA and the bottom plate that the pin locks through. [/QUOTE]
Verification
Post reply
