Other Brand Skidsteer Forums
New Holland Skidsteer Forum
LS170 charge pressure light switch
Reply to thread
Message
<blockquote data-quote="frogfarmer" data-source="post: 71917" data-attributes="member: 4075"><p>I have replaced dozens of those switches. Not just my machines. After 6 or so on mine the wires were unhooked. Havent seen a new switch that was bad but have seen several with little run time. Don't remember the exact specs for charge pressure but it is in the 150-200psi range. 180 is good. Make sure the air is out of the system before you condemn the switch but it sounds like you have a bad one.</p></blockquote><p></p>
[QUOTE="frogfarmer, post: 71917, member: 4075"] I have replaced dozens of those switches. Not just my machines. After 6 or so on mine the wires were unhooked. Havent seen a new switch that was bad but have seen several with little run time. Don't remember the exact specs for charge pressure but it is in the 150-200psi range. 180 is good. Make sure the air is out of the system before you condemn the switch but it sounds like you have a bad one. [/QUOTE]
Verification
Post reply
