Other Brand Skidsteer Forums
New Holland Skidsteer Forum
LS160 Hydraulics Alarm
Reply to thread
Message
<blockquote data-quote="Mike10" data-source="post: 45946" data-attributes="member: 5461"><p>It is probably the pressure sender at the hydraulic filter mounting base. Remove the right engine side panel and look at the filter base, you will see a pressure sender with two wires going to it. Common failure, just replace it.</p></blockquote><p></p>
[QUOTE="Mike10, post: 45946, member: 5461"] It is probably the pressure sender at the hydraulic filter mounting base. Remove the right engine side panel and look at the filter base, you will see a pressure sender with two wires going to it. Common failure, just replace it. [/QUOTE]
Verification
Post reply
