Loud grinding / screeching noise
wolf_fav
City & State/Province
NEW JERSEY
Hello all ,
I finally got all my leaks situated on my injector pump . I got in her today and started to mess around when all of a sudden I started to hear a loud grinding , screeching sort of noise coming from the left side of the machine . I almost feel like I could feel it in the T handle but didn’t want to run it like that for too long . Where do I start ? Where should I look ?
Any suggestions are deeply appreciated
Got machine up in air and figured out that at the very least the rear wheel bearing is blown out . The service manual isn’t very clear on the procedure to do the axel bearings . Any tips or trick any one can relay to me would be much appreciated.
Got machine up in air and figured out that at the very least the rear wheel bearing is blown out . The service manual isn't very clear on the procedure to do the axel bearings . Any tips or trick any one can relay to me would be much appreciated.
How did you make out on this? Mine is doing the same
