Bobcat Skidsteer Forums
loosing a major amount of hydraulic fluid... but can not see where..
Reply to thread
Message
<blockquote data-quote="Tazza" data-source="post: 33248" data-attributes="member: 82"><p>I believe the seals are on the chain case its self. Its been a while since i did this though. There is also an O ring in the drive motor where the shaft comes out. Its on the inside of where the shaft is, you can get it out without pulling the motor apart. I think its a brass housing/bushing, but don't quote me on that.</p><p>If you remove the drive motors, you will see what i mean.</p></blockquote><p></p>
[QUOTE="Tazza, post: 33248, member: 82"] I believe the seals are on the chain case its self. Its been a while since i did this though. There is also an O ring in the drive motor where the shaft comes out. Its on the inside of where the shaft is, you can get it out without pulling the motor apart. I think its a brass housing/bushing, but don't quote me on that. If you remove the drive motors, you will see what i mean. [/QUOTE]
Verification
Post reply
