Other Brand Skidsteer Forums
Case Skidsteer Forum
loader arm hydraulics problem
Reply to thread
Message
<blockquote data-quote="goose" data-source="post: 29303" data-attributes="member: 1582"><p>The problem with the loader dropping when you start to raise it or the bucking dumping is in the load check valves in the loader valve. Most likely the spring that holds the poppet closed is broken. Repair kit part # H673572 should solve that problem and may take care of your cylinder drift problem. If the drift problem is still there it is most likely one of your cylinders leaking past the piston.</p></blockquote><p></p>
[QUOTE="goose, post: 29303, member: 1582"] The problem with the loader dropping when you start to raise it or the bucking dumping is in the load check valves in the loader valve. Most likely the spring that holds the poppet closed is broken. Repair kit part # H673572 should solve that problem and may take care of your cylinder drift problem. If the drift problem is still there it is most likely one of your cylinders leaking past the piston. [/QUOTE]
Verification
Post reply
