Bobcat Skidsteer Forums
Lift/Tilt cylinders both drifting down?? Any suggestions
Reply to thread
Message
<blockquote data-quote="Tazza" data-source="post: 20878" data-attributes="member: 82"><p>That was the correct direction for the seals.</p><p>Cracks can be hard to see, i'd doubt you could see them simply looking in the ports.</p><p>Try lifting the arms and using your heel on the lift pedal, see if it slows or stops.</p></blockquote><p></p>
[QUOTE="Tazza, post: 20878, member: 82"] That was the correct direction for the seals. Cracks can be hard to see, i'd doubt you could see them simply looking in the ports. Try lifting the arms and using your heel on the lift pedal, see if it slows or stops. [/QUOTE]
Verification
Post reply
