ancomcabs
- Joined
- Nov 3, 2011
- Messages
- 299
Since rebuilding the 630 I've noticed a couple small leaks on the lift cylinders. I'm going to plan on replacing the seals and want to try an keep things as clean as possible now that it's back together and painted. I'll use Taz's method of draining as much fluid as possible with the aux connectors but when I disconnect the hoses I'd like to thread plugs back in to keep as much fluid as possible from leaking out while the cylinders are off. Does anyone know the size plugs I would need for this? Thread type?
Also am I right in assuming once the pins are out I should be able to pull the cylinder forward enough to gain access to the hose fittings?
Thanks
Thanks
