Lift & Tilt Valve won't light and pedals locked
cyerger57
I have an older S175 and when I start the machine and press the button the Lift & Tilt light won't come on and the pedals are locked. I've checked the codes and it says NONE. This has been an issue in the past and what resolved it was to jerk the machine back and forth a bit and then try restarting it. Sometimes it took 2 or three times to get it to work. The seat belt light is working and the bar light is working. I do not have a cab. One other thing. In the past I've found that if I leave the bucket off the ground a bit when I stop, the problem didn't occur. It always goes down to touch the ground but at least it wasn't bound up. I tried disconnecting the battery and reconnecting. The seat belt light appears to be somewhat intermittent but I've never had to use the belt before. It always ran fine with just the bar down. It's a bit redundant anyway, don't you think......? Please gentleman, I'm not a skiddy mechanic. If you have some idea of what to check, please be real specific about where the item is. I understand electrical things but don't know where things are on a skinny. The light for the bar as well as the other two come on just fine. If I raise the bar while running, all go out. Then I lower the bar and push the button, 3 lights come on but not the Lift & Tilt Light. It's really a bummer because I can't even load it on a trailer to take it for service because the bucket won't raise. I had this problem a little over a year ago but it was summer and I pressure washed the machine and that corrected it until now. I need to find out what the real cause is.
