So I am experiencing a left joystick error with the following codes: H3916 and D7501. I have checked the wiring for damage (none) , unplugged and cleaned all connection , and no luck. I can use the machine if I go very slow and gentle, but if I hit a bump or move the bucket too hard it triggers the code and the machine goes into park.
The dealer told me it’s very unlikely it’s the joystick, and it’s probably the wiring. According to the dealer, the whole harness has to be changed for $4k and 35-40 hrs of labor? I asked if they could test my joystick or try in another machine and they said no. I told him 95k sure doesn’t get you very much nowadays.
So today I called the Orlando dealer to see what they would say: they said it sounds like the joystick, and switch the, to see hat happens. So I switched the controllers from the right to the left, vice versa, and it didn’t produce any codes. The controls follow the joystick , so everything is backwards now but working. I expected to see a code for the right joystick now, but not zero codes. I am going to run the machine more now to see if it will throw a code eventually. I am thinking I did not run it long enough.
Any input or thoughts is appreciated!
