Leaking hydraulic fluid
hilltopdude
753 started blowing hyd fluid out the sides from the fan port. when I opened up the back fluid was coming from the fan shroud. Machine still able to steer and raise bucett. Pulled up the cab, and am not sure how to access the fan.
Open up the rad screen above the door and check the oil cooler and hoses
My guess is oil cooler too. My S250 had a wall of oil pouring down the back of the blower housing. The cooler rusted out on the sides. I spent the best part of a day chasing the holes with a sand blaster and silver solder.
Yes it looked like a waterfall coming out of the shroud. Both the radiator and the cooler did look wet but the compartment didn't have alot of fluid in it. Will hold the cooler up and start the machine tonight and see if blows the fluid out. New cooler is 185.70 at the dealer.
