nobull1
- Joined
- Jan 4, 2007
- Messages
- 196
For the last couple of months I have found that the Bobcat seemed to be dieing out (almost stalling) under heavy load and sometimes hard to start when left for any amount of time. The last couple of days for no reason the machine would just die and I had to squeeze the primer and prime the system After doing this, sometimes it would work for an hour or two with out issues. I decided to take a look at the pickup tube in the tank to see if that could be the problem. Lucky for me the grommet came right out and I was left holding the elbow and about a 1/2” of the pickup tube attached just above the bottom of the elbow. I suspect that the tube completely broke off while I was trying to remove the grommet because it would run with a 1/2 tank of fuel before I removed the grommet. I believe that the line was cracked or partially broke and allowing air to enter along with the fuel. Sometimes it would get more air when under load and enough to starve the system for fuel.
So I tried to get a new line, filter and check valve and was told by Bobcat it would be a couple of days. So I went to my shop and found a piece of 1/4” black rubber gas line hose that was a tight fit onto the elbow. So I just cut it to the length Bobcat said it was at 9.5” and installed it. I used the machine for about a hour and worked fine and seemed to have more power under load as well. For the cost of the parts I ordered them from Bobcat anyways.
The questions are
The questions are
- Is the black gas-line hose acceptable or maybe even better than the Bobcat hose?
- Do you need the clamps that hold the line to the elbow (must be small as there is no room for much more than the hose)?
- The old hose is in the tank so do I need the filter check valve or will it possibly cause more grief than it will repair (plugging up and having to remove the pickup to clean)? Or will letting the potential junk come through be a bigger problem?
