Other Brand Skidsteer Forums
New Holland Skidsteer Forum
L785 servo problems
Reply to thread
Message
<blockquote data-quote="PADeutzguy" data-source="post: 65029" data-attributes="member: 8986"><p>Talked with the dealer on Monday, he suggested we drill out the hole where the plug/plate was and tap it to 3/8' and put a flat plug in it. It worked. We did this by removing the piston and rod, drilled it out, being very careful to be square, tapped it, installed the plug (Advance Auto parts had one) and used a die grinder to grind back where the bearing goes in. Hoping it's going to last a long time. Thanks for all your help.</p></blockquote><p></p>
[QUOTE="PADeutzguy, post: 65029, member: 8986"] Talked with the dealer on Monday, he suggested we drill out the hole where the plug/plate was and tap it to 3/8' and put a flat plug in it. It worked. We did this by removing the piston and rod, drilled it out, being very careful to be square, tapped it, installed the plug (Advance Auto parts had one) and used a die grinder to grind back where the bearing goes in. Hoping it's going to last a long time. Thanks for all your help. [/QUOTE]
Verification
Post reply
L785 servo problems
