Died on me suddenly ran the battery down trying to get it to start. Charged the battery overnight and pulled the sediment bowl because the drain wouldn't come out it was 1/3 full of some black goo and the glass was stained a dark red color. cleaned all that up and installed a new fuel filter. filled the sediment bowl and filter with fresh diesel pumped the primer bulb a whole bunch of times. crank and crank and crank never hit a lick. With the line circled in red loose I get a squirt of fuel with each pump of the primer bulb. I cant get anything out of the bleeder circled in blue pumping or cranking and I had a helper cranking while I loosened the line to the injector circled in green nothing. Is there a good way to check for a failing fuel shut off solenoid? Any help is greatly appreciated. I'm also looking for a manual for this engine if anyone knows where to order one. https://imgur.com/a/kpX3F7W
