I got another question for the experts. My skidsteer slowly gets hotter and hotter while moving dirt. I have not let it get above 212 yet because I do not want to wreck anything. I took out the thermostat and it does the same thing with it in or removed, but I dont know if that means anything. I had taken out the radiator a few weeks ago and I cleaned it out with hot water and a brush and compressed air. (my pressure washer does not work right know). It also seemed to me like there was good flow through the radiator, if you filled it all the way up with water and let your hand off of the bottom outlet the water would all gush out in about 3 or 4 seconds. If you take off the radiator cap while the skidsteer is running you can see the coolant slowly move through the radiator but very slowly. How do I know if I have a bad water pump? Is it possible that I have air in the cooling system somewhere that is not allowing circulation, and if so how do I get the air out? I just noticed last night my bottom radiator hose was leaking a little bit so I am going to go by a new one and a new thermostat on Monday. Paul
