farmgirl07
- Joined
- May 9, 2010
- Messages
- 5
hi all. i just joined the forum. so here's the skinny. i have an old l555 with a kubota v1902. machine has been sitting for a couple years. i found the fuel cap off. dont know how long it was off! anyways, i totally flushed and drained the fuel tank, and changed filters, put fresh fuel in and some lucas. also did oil and filter change. motor starts right up. now the problems. lots of blowby from tube coming off the valve cover. strong oily/diesel smell, although machine doesn't seem to burn that much oil. we did a compression test. cylinder #1 (closet to operators seat) was 280, cylinder #2 & #3 were 320, and cylinder #4 (closet to radiator) was 360. also noticed a small leak near head gasket on cylinder #1. machine almost seems to be running on 3 cylinders. not sure. we will be doing a leak down test in the next few days to try and pinpoint the issue. there is no antifreeze seen in the oil. hoping its a headgasket and not rings. i would like to get this machine up and running before i give it a paint job. any input would be appreciated. thanks in advance. -farmgirl
