L555 Kubota Glow Plugs
solakian
L555 with Kubota V1902-B engine. Which Glow Plug? NH Part# 9827560 replaces two Kubota part numbers, 15806-65512 (Quick glow plug) & 15521-65510 (Glow plug). Does anyone know the difference between these two? Both are available through Kubota parts. Can I use the quick glow plugs on my 30-year-old machine?
NGK #'s are Y 706R (quick) and Y 106V (standard)
I am not sure of this but I would assume that the quick heat ones will draw more amps than the standard heat ones, so you need to determine if your wiring is of a heavy enough gauge to carry the extra load. remember when figureing this out there is what ever amp draw is per glow plug that is times four.
